Results 81 to 100 of 101
05-09-2009 #81
I need to sell my boat asap! I want this setup!
05-11-2009 #82That's front subframe clearance.
Our triangulated 4-bar does not work well with 12-bolts, due to the width of the cast center. If we moved the UCAs outward, the links would shorten too much and cause nasty roll steer and pinion angle changes. Also, we try to keep the angle of the links (in a plan view) as they are for lateral stability.Matt Jones
Mechanical Engineer
Art Morrison Enterprises
05-11-2009 #83You can view some photos some photos here:
http://www.artmorrison.com/gallery/v...ontClip&page=1
We don't have any of the tri-4 bar taken yet, but the 3-link is pretty similar. The only difference is the 4-bar requires no UCA hoop, and therefore no floor cutting.Matt Jones
Mechanical Engineer
06-08-2009 #84Mine should be shipping next week, cant wait to install it. Any tipe on the install?
06-08-2009 #85Looks like my exhaust...
Kevin.
69 Firebird "Eternity"
06-09-2009 #86
06-09-2009 #87It's really pretty easy. First, place the rear caps into the frame rails. With the stock frame rails removed, insert rear of subframe into the bumper/rear valence area. Then, use a floor jack to raise the front crossmember into place. With a tape, make sure it's squared up pretty well, then get another floor jack to press the rear of the frame rails tight against the trunk floor, and do the same with the front jack. The idea is to get some of the cars weight onto the subframe to ensure a tight fit. When you're happy with the placement, place a few stitchwelds between the trunk floor framerails, rear valence, and front crossmember. Done!
Matt Jones
Mechanical Engineer
06-09-2009 #88
07-09-2009 #89Thanks guys. Got all but my axles and gearing today. Im guessing that side is coming from Frank. Everything was boxed up and on the pallet nice and neat! One thing though, is there any instructions? I cant wait to get this baby installed! Take one more part off the list!!!
07-13-2009 #90Heres a shot for those of you on the fence. Its the stock frame rails compared to the Morrison piece.
07-14-2009 #91
07-15-2009 #92Matt, there are many canted 4-bar systems out there on 12 bolts and I haven't read any negative feedback on them. Would you elaborate on your statement about the UCA's being too far apart and just what you mean by "nasty roll steer"? Which has more impact on roll steer, UCA separation or side view angle of the UCA's?
Would your Tri 4 Bar suspension package work on a 1st gen 12 bolt? I love your companies products but I'm too for along for this new kit your talking about in this thread. Thanks!
07-15-2009 #93All of the things you mentioned will have an affect, but it all depends on how much of a change you make.
If the UCAs are widened laterally, they link must get shorter to match up with the bracket on the rail. Too short of a link will cause the housing to steer radically in a roll...how short is that? Honestly I don't know, it isn't something I've tried. We do have customers who have used our tri 4-bar kit on 12-bolts, and typically they'll lessen the UCA plan view angle, which is OK to a certain degree. We try to tell customers to keep the UCAs at 30* or more (plan view again, relative to the frame rail) for lateral stability. There indeed are many triangulated kits on 12-bolts, but we'll only offer ours in a way we know works the best possible.
The only way I can see our clip working with a 12-bolt is if we left the UCA frame brackets tacked on, and the housing brackets loose. I'm quite sure you'd have to modify both frame and housing brackets in order for it to work. For as much as you can sell a 12-bolt for a first gen Camaro, I'd go ahead and do a 9"...Matt Jones
Mechanical Engineer
07-15-2009 #94
