    Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
    Results 61 to 80 of 101
    1. #61
      Aug 2003
      Awesome as always guys.
      We should have a order for one of these rear subframes coming your way real soon. We want to sell the first one!
    2. #62
      Sep 2001
      Accord, NY
      Matt, interesting exhaust! Headers into mufflers into 'X'?
      68 camaro - SOLD
    3. #63
      Auburn, WA
      Quote Originally Posted by Rick Dorion
      Yes, it's not something you see everyday. I was a bit worried about how it would sound, so I had it all tacked together first and fired the motor. Turned out to sound pretty darn good, lots of people comment on it.
      The LS engine is pretty mild, so it's comfortable at cruise and idle.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
    4. #64
      Auburn, WA
      Quote Originally Posted by ProdigyCustoms
      Thanks a bunch Frank!
      Turns out the first two are already sold. Get this: The first is going into a real-deal ZL-1 COPO '69. Bought our front subframe as well!
      Matt Jones
      Mechanical Engineer
    5. #65
      Jul 2008
      Australia
      Quote Originally Posted by silver69camaro
      The car still has 275mm tires in back. Maybe because I'm an engineer, but I try to stay away from excess.
      That made me laugh, I have a friend who's an engineer (In a different field), he would say exactly the same thing. It must be some sort of engineer conspiracy.
      For whatever reason, some of us are different and tend to err on the side of form over function.
      Thanks for the info
    6. #66
      Oct 2006
      Colorado
      Have you swapped the suspensions yet? Any comparisons between the 3 and 4 links in driving experience?
    7. #67
      Oct 2006
      Colorado
      Quote Originally Posted by MoparCar
      Any news?
    8. #68
      Fife, WA
      Matt is driving the car with the 3-link setup right now and has about 600-700 miles on it already. He's out of the office now, but I'll have him chime in on this thread.
    9. #69
      Quote Originally Posted by CraigMorrison
      any updated pics?
    10. #70
      Jan 2009
      Any updates? I was thinking of buying it and was wondering how the tri 4-bar corners.
    11. #71
      Auburn, WA
      Honestly its very difficult to tell the difference between the triangulated 4-bar and the 3-link. If anything, the 3-link might have slightly more foward bite due to higher anti-squat, but that's about it. Lateral control feels the same (as it should) and it's just as easy to handle it on the edge at the apex. I'll see if I can get some new photos up.
      Like I mentioned recently in the Lateral-G forums, the triangulated four-bar clip is a hands down winner. Cheaper, no floor cutting, and excellent handling. I think the true benefit of the three link is the ability to run spherical rod ends, which is awful on the street anyway.
      Matt Jones
      Mechanical Engineer
    12. #72
      Auburn, WA
      Wish I had some photos on the lift, but I don't at this time. It's on jackstands right now getting some electronics upgrades, so I'll get some more.
      Matt Jones
      Mechanical Engineer
    13. #73
      Jan 2009
      I am sold on the clip and plan to order soon. Can you recommend subframe connector setup with this? It looks like you used some 2x4 tubing on your setup. I would rather not cut the floor pan so I was planning on using some Hotchkis connectors and modifying them to work with that crossmember. Would this be strong enough or should I just follow your lead and cut the floor?
    14. #74
      Auburn, WA
      We actually have 2x3 subframe connectors for this clip, and you do have to cut the floor. If you want all the stiffness you can get, you MUST cut the floor. It's not a real big job and it's well worth the effort.
      Matt Jones
      Mechanical Engineer
    15. #75
      Jan 2009
      Great, thanks for the advice. I will patiently await more pics.
    16. #76
      Auburn, WA
      What photos would you like?
      Matt Jones
      Mechanical Engineer
    17. #77
      Oct 2006
      Colorado
      I know I've asked before, but are you sure you won't make this rear clip for a direct fit e-body mopar any time soon?
    18. #78
      Auburn, WA
      Quote Originally Posted by MoparCar View Post
      Heh, I'm sure. It's not that it can't be done or we don't want to, the problem is we're stuffed to the max and wont really be able to create any new projects until our new building is up and ready. We have just a couple bolt-on frames on the plans right now and wont be able to expand at the rate we'd like until probably next year.
      Matt Jones
      Mechanical Engineer
    19. #79
      Jan 2009
      Can you post some good pics of the tri 4 setup?
    20. #80
      Jul 2007
      Olathe, KS
      Quote Originally Posted by silver69camaro View Post
      It's about 5.25" between subframe and ground in this photo.
      Is that front or rear subframe clearance? How much ground clearance do you have at the ends of the coil over mounts?
      Have you guys thought of how this would act with a 12 bolt with cast center? How much of a difference would you notice due to the axle end of the upper links moving outward?
