Thread: Front tires hitting fender
4 Weeks Ago #1Registered User
- Sep 2007
- 162
Hello guys, it’s been awhile since I have posted. Life just never seems to slow down. A problem arose that I was not expecting. My front tires use to rub when traveling over big bumps. After dealing with this for years and finally realizing a new front set up is not going to financially happen I decided to at least install taller upper ball joints. The rubbing is now worse. The tire hits between the 1-2 o’clock position on the passenger side and 10-11 o’clock position on the drivers side. Is it possible that the taller ball joints put the spindle is a worse position in the camber curve?(which I didn’t think is possible). The following is my setup:
67 Camaro, big block springs, 2” drop spindles, disc brakes, 17x7 wheel w/ 3-3/4BS, 225/ 50 tire.
