    Results 1 to 20 of 26
      1967 Cougar Godzilla ZF 8HP70 swap
      A book has many chapters, and one can argue that the Cougar story already has many chapters. Calling this chapter 2 doesn't seem fitting, as this is more like chapter 4, but whatever. Here is a link to the last few chapters:
      https://www.pro-touring.com/threads/...es-and-videos)
      Every journey starts with the first step, and here is the first step of this journey:
      This is a 2021 7.3L Godzilla from a wrecked F250 truck. The plan is to keep the shock towers and the current front suspension setup. Engine management will be handled by the Holley Dominator ECU which will be integrated with the TurboLamik TCU that will control the ZF 8HP transmission.
      I don't know how quickly this project will move, given our move to Texas in the next 60 days, but it would be awesome to have it ready for the Holley Ford Fest in late September.
      Instagram @projectgattago
      Dr. EFI
      Hildebran, NC
      This will be cool setup!!
      Sidenote....Does Holley make a twin trottle body tunnel ram for a godzilla yet????
      LOL
      Quote Originally Posted by rchaskin View Post
      LOL
      Sadly, they do not, but I like the current sleek hood.
      Dr. EFI
      Sep 2009
      This is going to be amazing!! Lots of buzz words in your new thread title!!
      Aug 2006
      Star,Idaho
      Wow. Kudos for keeping the shock towers. Looking at doing the same swap later on. Looking forward to the build.
      70 Cougar
      Aces Kill shot efi
      T70 Turbocharged 302 430hp 488tq
      Tremec 3550
      13" Cobra brakes
      Unisteer Manual rack
      May 2010
      British Columbia
      That's what I call an step up and to pull it off with the shock towers in place is going to be a test. When I decided to go with the TCI set up was to make life easier plus I needed to rebuild the frontend anyhow. Did you still want me to send you pictures of the DSE QUADRALINK rear suspension upper control arm attachment mounts
      Oct 2010
      SLC
      Very cool.
      Zach
      Quote Originally Posted by langleylad View Post
      If you can, no rush...
      I have been working with TurboLamik, for the last several month, on having full integration between the Holley EFI systems and the TurboLamik TCU. What this means is that the two will be connected with just 2 wires. This applies to the Holley Dominator and HP using V6 and also to Terminator X and X Max using V3. The Dominator and Terminator X Max are optimal because they have two CAN busses and DBW throttle.
      The TCU needs information in order to make shifting decisions. Namely, it needs RPM, TPS, MAP, and torque output. Those are the basic channels that are a must, however, in order to make the transmission work optimally, the TCU needs to send messages back to the ECU.
      The most critical is a signal to retard the timing during upshifts. This is commonly known as torque management and all modern transmissions implement this strategy, both for smooth shifting as well as transmission longevity. It can also be extremely helpful to retard the ignition during shifts to keep the tires from spinning during hard upshifts. With a very powerful engine, it can actually be pretty dangerous to upset the car during a full throttle upshift. This feature is now working between the TCU and the Holley ECU.
      Another feature that goes along with torque management is throttle blipping on downshifts. This feature isn't strictly necessary, but it too will be available, although somewhat limited, because Holley...
      The TCU will also send the following information: Gear, transmission temperature, speed, converter slip, and clutch slip. All of this information will be available to be displayed on any of the Holley digital dashes, not including the 3.5" handheld.
      If there are any questions, please ask.
      Dr. EFI
      Mountain Springs, Texas
      Nice work!
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Nov 2018
      Excellent! Adding a Holley ECU to my project now if it can speak back and forth to the Turbolamik. I do have a question, can any of the Holley ECUs that can speak to the Turbolamik also handle dual DBW throttle bodies?
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Beach Park IL
      The dominator can handle dual throttle bodies. Andrew has done it.
      Limited how? Can the converter unlock during downshift to make the rev match less critical? Is this only an issue when using paddle or sequential style shifters?
      Donny
      Nice work!
      Don
      Thanks Don. We are really looking forward to moving to Denton!
      Quote Originally Posted by Vimes View Post
      Yes, I used to have dual DBW throttle bodies on the Cougar when I built it 9 ears ago:
      Holley limits DBW offset to +10% (no limits on negative offset). In talking with Lukas, he seemed to think that this was going to be enough.
      You are asking excellent questions, but I do not have the exact answers, yet.
      Dr. EFI
      Nov 2018
      Sweet.
      2021 Durango R/T
      2005 Dakota beater
      Oct 2023
      Very cool! Subbed for updates!
      '70 Maverick. Prestige Motorsports 347,TKX, Currie 9", 3:50 posi, RRS suspension. Strut front, center steer rack, 3 link torque arm rear, QA1's.
      Oct 2010
      SLC
      Or.............put the godzilla in the front of that ranger ;)
      Zach
      Progress is being made. Scored some Mast Motorsports CNC ported heads for the Godzilla.
      Still exploring various options for the cam. If anyone has some recommendations, I am open to suggestions.
      Dr. EFI
      Sep 2009
      3/4 race cam should have you popping coke cans in no time.
      Jun 2012
      N. Shore, Ma
      Should be fun Andrew!
      I've been following this Cougar since 2014!
      Eric
      Building 1969 GTO - Roadster Shop chassis, LQ9 w LS3 heads and rebuild parts from TSP, Bowler prepped Magnum T56 6 spd, 3 Link Strange 9" w Speedway Floater Hubs, Wilwood 14" F - 13" R brakes, 275.18 - 345.19
      https://www.pro-touring.com/threads/94970-69-GTO-Build
      Quote Originally Posted by ekmxryda View Post
      Time flies when you're having fun!
      Dr. EFI
      After going back and forth and exploring as many cam options that I could find, I decided to go with a cam from Mast. It is their Godzilla 7.3 HO cam and the full specs can be found here:
      https://www.mastmotorsports.com/coll...lla-cam-100264
      The torque and power are represented in red in the graphs above. It really seemed like the "goldielox" cam. It loses a little torque below 3000RPM, but above that point it makes more torque everywhere, including the stock cam. It doesn't make quite the peak HP numbers that the bigger, Godzilla 7.3 GT cam (green lines), but it is darn close, without giving up significant torque down low.
      These numbers were generated with the CNC ported heads that I have and a stock intake manifold.
      Comments and suggestions are always welcome.
      Dr. EFI
