Results 281 to 300 of 885
08-08-2010 #281Registered User
- Mar 2008
- 952
the most i've ever spent for a new set of headers was $225 or so for a set of jet Hot coated Dynomax headers about 12 years ago, so anything more than that is a fortune.
i can't believe that there aren't any good cheap long tubes out there- it is a car that they made 1.5 million of over a 10 year period...
if i can't buy a set of cheap long tubes that don't drag on the ground, then i'll find a set of used shorties and make then into long tubes- maybe even tri-Y's or something weird like that.
of course, then i'd have to snake the exhaust over the rear end and past the panhard bar mount on that side of the car, but that might not be too bad..
i'm not scared of reworking the floor to run a tube down the driver's side- i could tie into the home made subframe connectors i'm dreaming of and use a different trans crossmember/torque arm mount to tie the car together better. that's another thing i want to do- get the torque arm mount off the trans tailshaft.. what the hell was that all about? that would make running different transmissions easier..
why all the trouble? why not? i've never heard a V8 with single exhaust that sounded right- but i do, however, love the sound of a high strung small block with an X pipe and Flowmaster mufflers. that, and it looks stupid as hell having the exhaust run over under the passenger footwell like that..
